Use this procedure to view SBT entries.
The following table defines parameters for the show ipv6 fhs snooping binding command.
Variable |
Value |
ipv6-address WORD<0-46> |
Specifies the IPv6 address for the binding entry. |
type {dynamic | static} |
Shows only dynamic binding entries or static binding entries. |
vlan <1-4059> |
